I don't have an actual VR Headset. But have been fiddling with emulated VR. Even shutting down Steam service does not help. Every time LumenRT is started in evaluation mode, it launches a Headset Window and after closing that, the "VR Compositor" window. Where can I disable VR?
Is there any way to stop this other than uninstalling SteamVR? (This is no longer the evaluation edition)
Has anyone found solution to this? I have a VR headset but don't want to use it with LumenRT.
