I want make simple logo animation - see - i make keyframes and want to see how keyframe is rendered
but luxology still render first key - view top
Turn off constructions.
JF
Propably i make element on construction and turn off element with origin cell... is there any way to keep keyframes if element is ungrouped and changed to primary ?
How about Luxology problem below ?
To see a frame rendered at a point in the timeline, you will need to render that frame using the Animator Record script start frame # end frame #.
