Bug or Feature? Mirror in Environment.
Hallo,
in Connect Edition update 10 we realized, that the mirror controlbox, if set to false or true, all named setups are affected. That is  a little bit dangerous.
The other options are only for the named setup, which is shown in the title.  Is this a bug or a feature?
We also realized, that sometimes we set it to false made a save settings, reopened the file and the option was not set as saved.
Can you reproduce this?
Kind regards
Gerd
