When I try to create a stereoscopic Spherical image in LumenRT, I see the stereo option is not available.
This option is only available with the standard format, but the result of this option is not usable with VR goggles:
Am I doing something wrong, or is this a bug?
Regards Louis
Hello Louis ,
Issue with Stereo is fixed with Update 10
Old defect number is Defect 908398:Stereo output saved with resolution 4K and above with stereo Side by side shows 4 instance instead of just 2
Thanks & Rg
Harshad
Thanks Harshad,
The frequency of the updates is higher then I suspected.
Hi Harshad,
I just installed update 10 of LumenRT.
The stereo option looks to work alright in Standard format. In 360 VR Panorama however, this option is stil dark. Do I understand it alright than when using Google Cardboard, there is no user-friendly way to save in Stereo and Spherical mode on?
Hello Louis,
stereo option is not available with 180 & 360 VR panorama, its only available with standard image and video format .
I saw some peculiarities in U10 (can't place objects(trees, etc.) anymore). Today I hope to test this again and if the problems are stil there I make a new post.
