In MicroStation Connect Beta x til Update 10, materializing a, for example, solid does not react like it should be (see screenrec). If a material is attached to a solid, many often it's not shown. Also the projection doesn't work like it should be.
Will this be solved in the next version?
Regards Louis
Hi Louis,
Can you try with Update 11? This should be fixed there was a problem attaching to parametric solids and I see in your video that is what the geometry is.
Jerry
Answer Verified By: Louis van Amerongen
Thanks Jerry,
After installing update 11, the materials where visible on parametric solids.
(now I can show the parametric functionality during our tmc event without worry)
Cool glad to hear it.
Cheers,
