I have used a set of RPC cells for years. I updated to Connect Edition (Update 11) and noticed that Microstation CE will terminate if I try to use them. Those RPC cells have been working fine since V8 era and work perfectly fine with V81 SS4, for example.
Hi Yrjo,
I just added a few RPC to a scene with no issues do you have a scene that the RPC already placed into that causes crash if so I might need that test case. Opening a file with no RPC and adding new ones is working for me.
Cheers,
Jerry
I managed to limit the problem to a bunch of commercial RPC cell samples. Luckily, all my self-made RPC cells seem to work ok so I just dumped the commercial samples to another folder for time being.
However, there is a strange problem with view modes - 'Illustration' or other rendered view modes do not render RPC cells in my old V8i models properly (just a grey rectangular without the image). I have to create a new empty dgn and copy the RPC cells from the old V8i model to the blank dgn. After that they will render ok.
Furthermore - It is not enought that I need to copy rpc cells from my V81 dgns to a clean new file but I have to re-create all the saved views as well. That means, I am not able to get the same settings and camera angles as before and my previous Photoshop steups will be useless.
Uh, it was a bad mistake to try Connect Edition UPD11. Going back to V8i...
Can you please send me a file and an RPC so I can look into this.
Paul
