Image below shows solar exposure run for a model.
True North is up on screen (set as 90 degrees from X axis in light settings)
The result assumes true north is to the left. The blue (0 hours sun) should all be shown above the buildings in the image. Changing the solar position doesn't seem to have any effect on it.
Hello Duncan,
I have tested issue reported in Current release build CE 11 . I am not able to reproduce issue and i can see expected result with respect to True North direction set.
Above image with True North = 90Degree
Above image with True North = 180Degree
Thanks & Rg
Harshad
I have tried with U11, U10,
ABD U3 and ABD SS6, all give different results.
ABD SS6 was the only one which gave a correct result.
Working in new files now on a different project, getting the same results. True North is ignored see further example below.
Hi Duncan,
I saw the Sr you have created. I will follow up with you on this
Maria Garcia
Not sure why but the reference file 1088_3d_Rayners Lane_option 9_N0201.dgn has the degrees from X for solar set to 180 instead of 90 degrees. If you open that file and fix that the results will be as expected.
Cheers,
Jerry
Answer Verified By: Duncan Gammie
