Can someone explain the workflow to be able to view a design I've created in LumenRT with and HTC Vive VR headset? I've got the Vive software installed and the headset seems to be working with the controllers, but I am clueless as to how I can navigate the environment I've created in LumenRT.
With the headset plugged in and Steam running, is your project visible in the headset once you start LumenRT?
Turns out I was running LumenRT Designer, an not LumenRT Pro. Once we updated my license to LumenRT Pro, things worked just fine.
