I keep having an error in my scene with the sun and sky. All of the photos and videos from it have a very strong backlight glare and the blue sky and clouds weren't showing up. I've tried adjusting the time and the I've tried loading a couple different terriains and it has the same issue. When I zoom out as far as possible, you can see the blue sky and clouds as a circle above the scene. See the pictures below, I may be having a hard time describing it.
Signs are hard to see.
Does anyone have any ideas of what's causing this? I was hoping to get this cleaned up for an animation on Wednesday. I've added a good bit of traffic, so it'd be nice to preserve that if possible.
I'd suggest using Physical sky option in the Environment Settings and see what happens.
