LumenRT crashes if trying to import this object.
orthodox_c.obj
Hello Oto,
I am able to reproduce crash with attached Obj and create defect for same.
will you please let us know more detail about file such as , from which software Obj is created ? version of software
i am able to import OBJ in to Microstation and export to LumenRT without issue
Thanks & Rg
Harshad
Can you please create the Service Request for the same.
So that we can keep the record and follow up on this issue.
Thanks.
Rg,
Ankur Ashesh
It is from Sketchup 3D warehouse - https://3dwarehouse.sketchup.com/model/d04604bfa31c13552557596709cf3f20
And exported using 2018 Sketchup
Thank you so much for such a quick and fast response and SR number.
We will file the defect for the same and share the number for the reference.
