V8i setting a display override by element works with cached views and translations making it possible to always force the display style of any element regardless of presentation.
CE this doesn't work the cached views ignore the display override and makes the element hidden.
-Grant
Hi Grant,
what MicroStation CE version? There have been 12 versions released, so to specify in what version the issue was found is crucial.
Don't you have some test case you can share? To simulate and setup properly cached view with style and override is not simple, so it's easy to end with different configuration.
With regards,
Jan
Jan,
It's a bit more complicated because we're running ABD but the ABD people consider this a "Microstation issue" when I've had things like this come up so i come here. (till a year ago we exclusively ran Microstation and only recently adopted ABD)
That being said it would include up to MS-CE - U11 per the ABD U4 patch notes
As for setup if you make the following display style in V8i...
Now apply that display style directly to an element like a line in this case given it's a Center Line display style...
The end result is the following in v8i & CE respectively with a cashed hidden line view.
This has proven a very effective way to maintain modeling Center lines in drawings with duct work, pipes & equipment center lines we want to keep for datum purposes.
We've created a similar override to force objects to not show any hidden lines ever which works well with auxiliary modeling items like vendor equipment, 3D people, and any other object that hidden lines are not necessary and just clutter a drawing. This was something we manually did before adopting dynamic views by cleaning up old EVE's, this solution was a requirement for us to create the high quality drawings our customers expect.
If this is somehow actually an ABD specific issue then i'll attempt to take it up with that side of the company but so far it's been a challenge to resolve "MS" related issues with that side.
Wow, I wish everybody would provide such detail description of their issues! Congratulations!
It looks really a bit complicated, despite of the main concept is quite clear, so I hope somebody from Bentley will be able to simulate the same situation and test it.
As long as it possible to create the situation in MicroStation only, it should be MicroStation issue. Of course ABD adds own features on top of MicroStation display process, so when MicroStation will (potentially) work fine, it will be time to test it with ABD also ;-)
Thank you, i try to document issues to be fixed if I can get people interested in them. I would be happy to test this in MS myself if bentley provided you a key for MS if you owned ABD given ABD is sold to you as MS + extra features.... but sadly given we have ABD i cannot test it in MS without paying extra so all i can do is ask the community for help.
It is also worth noting i did tihs example in ABD-Microstation only mode.
