LumenRT interior lighting [Connect U11]
At yesterdays Viz SIG I commented that interior lighting doesn't seem to work in LumenRT. Here is an example
Here is a simple Microstation model with 4 point lights. AS you can see they work in a standard Microstation view.
Here is the Microstation render window.
The lights are working.
Here is what I get in Lumen with the solar turned right down. No spot lights that I can see.
Here you can see that Lumen recognises my lights (Note I had to rename them as otherwise it only finds the first one.
An here they are as selected (but no actual lighting)
Here we are with the lighting set to full. No difference.
LumenTest.dgn
File attached. Can someone tell me what I'm doing wrong?
