I have installed AECOSim Connect on a number of Computers - all during install say I have LumenRT
But where is it??? There are no icons to run as we did on the pre connect version.
If I am to install then I assume this si the limited Free version as part of Aecosim?
And if I am to install do I install all 9 files on the fulfillment center?
Previously I had to and had to install them all in order for every thing to work
To check that LumenRT is installed it should reside in the following C:\Program Files\Bentley\Bentley LumenRT CONNECT Edition - Update 12
The tools to export to LumenRT is under the visualization workflow under the Home tab. See the following:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v14/en/GUID-34B5A509-BB50-4ED8-A4BA-5A5A48830B34.html
What David has said works but the nice function Connect has is a search bar in the top right corner... that tool is connects best friend and your saving grace for the ribbon interface. Type "LumenRT" and press enter
