When exporting a model to Lumenrt, random elements are assigned to level 0 in Lumenrt but I do not have level 0 in my design file or in the attached reference files.
Can anybody explain how to avoid this?
I've experienced similar problems (although slightly different) - elements existing on "Level A" in the DGN sometimes randomly assigned to "Level B" in LRT. Possibly related to your issue.
Max
Hello Martin,
sorry for the inconvenience, we have tested on heavy file and able to reproduce your issue.
for this concern, we have already filed defects, following are the defect numbers:
1.Defect:1006458 -Element highlight by layer color not working properly , change to layer highlight color highlight elements which are on another layer
2.Defect:1010341 -Layer color overlay: wrong color when there are more than 16 layers.
we will resolve these defects in further update.
Thanks.
Shubham Sharma
Thanks Martin.
Dear Shubham,
I have now tried with the original file and it still has the problem.
If I could send you the file you will see that many of the glass roof options (on separate levels in Microstation) all appear on Level 0 which does not exist in the Microstation file.
How can I upload the file, it is large
