Snowy forest
Hi, I need to add a snowy forest to my LumenRT scene - I can download and import some 3D snowy trees into LumenRT, but because these 3D objects are mostly quite large in size the forest doesn`t work very well, so my question is - are there a workflow for adding some snowy trees into a LumenRT plant library? If yes, then when will this happen? Thank you in advance!
