Can someone shed some light on why I am experiencing what I would call "glare" on all my elements? I'm new to Luxology and there are way too many settings that I have no idea about
All steel elements should be dark grey but the come out glaringly white
Maybe this help
Answer Verified By: J-Worker
I agree with martin's comments. Looking at your sample dgn I think the main thing to do is adjust the brightness on your rendering.
Once you have adjusted the brightness setting be sure update the Light Setup by doing the following:
This will make sure these brightness adjustments will be used for any new renderings.
Regards,Ron
Thank you for your input gentlemen. This is already looking a whole lot better
Can someone tell me how to make the grass look less like tiles?
Thanks again!
Hi.
1. In material editor use slider - COLOR < > PATTERN - move it little bit left and add little bit more green color than pattern
2. Click on PATTERN map and make this map bigger 4x4 m for example or use other texture from internet
for example i made some grass in Photoshop ( see attached my textures )
3. You can use in material settings FUR or DISPLACMENT too ( very long rendering ) or 3d grass from Landscape.pal
Brilliant! Thank you for your help :-)
