The structure is exported from MicroStation Connect to LumenRT.
It contains cells. Here is the image in LumenRT.
To get this right, I have to drop all cells, then drop all feature and smart solids to surfaces. then some parts are loosing the material attached to them.
Can someone help me with this problem?
Hello Roumen,
Can you please share the file with us.
We would try to reproduce at our end, you can upload the file in the below link.
https://bentley.sharefile.com/r-rf14af03e98446259
Please send us both the file the cell one and the normal one.
Thanks.
Rg,
Ankur Ashesh
Thank you for the files.
Will keep you updated.
Yes we were able to reproduce the issue at our end.
We have filed the defect for the same.
Here is the defect number for the reference - Defect 1034138 (Issue cells, feature solids and smart solids export to LumenRT)
This will be fixed in the coming update of MS.
