Hi Guys,
Creation a traffic simulation in Microstation using Lumen vehicles cell library looks fine - cars are coming on the path line (picture attached) and they are moving on preview animation tool as well.
After exporting into Lumen there are two options keep coming. The first one is: cars appear from time to time into different places for a couple of seconds. So the good thing is they are moving but not along the path they are supposed to. Another option is: all the cars are visible right after Lumen starts but are not moving. The good thing is they all are visible.
Both options are not kind of result to be glad about.
Creation of simple four-corner shape and simple line object as a path just to check the software is working looks fine (picture attached) in both Microstation and Lumen.
Possible conclusion is something wrong with surface or paths which are in used .
It would be not so bad if someone tried to chech those two guys on his/her machine please. It could take a couple of minutes. File is attached.
Thank You for Your time.
Lumen: Bentley LumenRT CONNECT Edition - Update 4. Builld: 16.40.49.49
Bentley PowerCivil for Sweden V8i (ss4). Version 08.11.08.789
Maksim
Problem.dgn
Hi Maksim,
I currently only have MicroStation SS4 [8.11.09.832], MicroStation CE update 12 [10.12.0.40], and LumenRT update 12 [16.12.23.02] installed on my PC.
I tried your Problem.dgn file by setting up traffic and exporting to LumenRT update 12.
It appears that the export of traffic from MS SS4 to LumenRT update 12 doesn't work.
If you open the dgn in MS CE update 12 and export to LumenRT update 12 it should work as expected.
Regards,Ron
Answer Verified By: Maksim Kolossov
Hello Maksim,
Ron is right it working fine with MS CE update 12.
As we have made so many changes and bug fixes from SS4 MS v8i to Connect edition.
Please try to use MS CE to get the traffic right it will work fine.
Thanks.
Rg,
Ankur Ashesh
Hi Ron,
Should LRT Up4 be uninstalled before LRT Up12 installation ?
Regarding Update 4: File called *LumenRT_Content.cel* is sitting in ProgramData-Bentley-BentleyLumenRTContent-Microstation.
After installation of CE Update 12 (MS and LRT) I do not see *LumenRT_Content.cel* file. The same story with Microstation folder.
Could it be there something wrong with installation or the directory has been changed ?
The install location for the LumenRT content cell libraries on my PC is C:\ProgramData\Bentley\connectsharedcontent\CellsForLumenRT
Cell libraries include:
Cars.celConstruction_Equipment.celLRT_Buildings.celLRT_Characters.celLRT_Misc_Transporation.celLRT_Plants.celLRT_Rocks.celSemi._Trucks.celSUV & PU Trucks.celVans and Buses.cel
