This is my first look at LumenRT and I'm not sure what I am doing wrong.
I am using CE Update 12. When I export to LumenRT I get the below message box appears. When I go into LumenRT there is an empty scene and none of my objects have been exported.
The directory that the CreateStream is trying to write to doesn't exist. Is this something I need to configure? Could the problem have something to do with the unc path and how our local drives are mapped?
Hi Simon,
Problem is with the path "\fmg.local\perth\..." which is not a valid path.This path is configured during installation of LumenRT, so maybe something went wrong during install, or as you suggest the configuration of your local drives is not correctly handled by the LumenRT installer.You can fix this path by doing this:- Browse to folder "C:\ProgramData\e-onsoftware" and open file "LumenRT 2016.reg" in a text editor.- Carefully edit the "DocumentPath" line as shown in attached image. Make sure you only change the path characters and do not delete any special end of line characters. I recommend this path: "C:\Users\<UserName>\Documents\Bentley\Bentley LumenRT CONNECT Edition" where <UserName> is replaced by your user name on your computer. This is normally the default path configured during installation.Hope this helps.
Regards,Alex
