I've received files exported from Revit to DWG - to be included in a Microstation model.
They all have long lists of RevitMaterialDefinitions as shown below. As far as I can tell, they're neither attached nor assigned to any geometry in the files, so I'd like to remove them.
If I select them all and hit delete, Microstation crashes.
It takes several minutes to delete each one at a time (there are hundreds).
Does anyone know how to remove them all at once?
I've tried going back and forth between DGN and DWG, with no luck.
Max
Connect - 10.12.00.40
v8i - 08.11.09.829
can you attached the file please
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Thanks for taking a look Brendan, attached is a clipped portion of the file.
I'm also finding the files are taking an unusually long time to load and are not practical to work with in their current state.
3Y.dgn
Hello Max,
Will you please share Test case and Crash log as well.
also have you tried workflow in Microstation Connect ?
Thanks & Rg
Harshad
Hi Harshad,
Yes, both v8i and Connect.
A test case was attached to my previous post in this thread. I'll see if I can get a crash log now.
- I've just done a test on the test case (deleting all materials in the material editor), and Microstation simply shuts down without creating a crash report.
Try creating external palette and material files. Loading them, and then unloading the local palette.
Michael.
