Hi
I realy like the new PBR materials, and also noticed i am able to use lights in realtime ( in the view port). Awesome! I did not find out if this also works for the sun, is it possible to also see the sun in realtime now in Update 13 somehow? If Yes, how would i do that?
Cheers
Helge
Hello Helge,
Sorry, currently Solar disk is not supported for display. currently we can add only image based environments in display style.
Thanks & Rg
Harshad
Hi Harstad
Okay noted, but that would be a nice improvement. To be able to use solar disk display, or just use DHRI maps as it is today.
Hi Helge,
Dynamic shadows will be in update 14, so you will be able to animate solar time and see the shadows track across your scene.
Cheers,
Jerry
Hi Jerry.
Cool! Its is good to see all the nice viz improvements comming up in Microstation! We also just implemented PBR-materials and sun ( that can be moved around using hot-keys ) in a CFD tool, it realy makes a big difference.
Cheers!
