I am using CE 13 and cannot view the Render Visible Edges after the render has processed as with CE 12.
It remains greyed out on the list.
Is this a glitch?
HI Dario,
a quick test worked for me. Do you want a screen share session? drop me a dm
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Hello Dario,
have you enable Visible edges on render dialog ? you can invoke setting from "More Image Setting > Display > Visible Edges.
Visible edges will not displayed in render preview window till Visible edge is enable.
Thanks Harshad, the issue was that the Visible edge option was greyed out,I'm going to do a reinstall/ repair to see if that helps.
OK resolved issue,If you fence an area to render than this stops the use of visible edges from being selected!
I have tested this in both V8i and CONNECT and this behavior is consistent across both. I will have to investigate but suspect this is WAD. as visible edges are calculated based on the view and when using a fence to define the render area the calculated edges of the view would not be applicable to the render area.
