What version of LumenRT should be installed with OpenRoads designer version 10.07.01.32
I have just installed ORD version 10.07.01.32. During the install process I was prompted to install LumenRT.
Problem:
1. Installation of LumenRT fails. When trying to activate LumenRT I get the following message. See capture below.
I would like to start using LumenRT.
1. What version is compatible with the ORD version stated above?
2. Any ideas why the install is failing?
Thanks. Cliff
