Hello!
I have previously asked question about how can we see material in fbx in Micro-station, yes it is obvious that if i made sample it collect material from local but if i open another file from different PC/laptop with .fbm folder texture is missing from micro station , can anyone please tell me how can I resolve this issue?
Hi Farhan,
Just copy all the textures from the fbm folder to the other PC, if you copy these to same folder as the DGN MicroStation will find them when you open the file.
Cheers,
Jerry
I do but its not working
Did you try opening the material editor up and looking to see what the path is to the missing textures?
Try adding the texture folder to search path maybe watch this video.
Answer Verified By: Farhan Uddin Shaikh
Thanks alot ... made it
