Problem with select / assign materials trough in illustration mode
I don't know if this right but
in U13 i have big problem -  can't  select / cut / assign materials  for elements that are hidden,  that are behind other objects  in illustration mode
For example i have a wall behind glass window.  I want to attach material to the wall  - but it's impossible in illustration mode - i can't select objects behind other
See also my tread
https://communities.bentley.com/products/microstation/f/microstation-forum/184595/connect---problem-with-visibility-cut-in-illustration-mode
Maybe is something in preferences / setup  that prevent illustration mode selection ? Maybe some select - view depth in illustration mode ?
and short video - see i can't select  >  https://youtu.be/JAlfZK4Xo2Q
