I have lighting symbols with associated IES data that is not showing as a light source in LumenRT.
Setting the rendering quality to maximum has not made a difference either. I am downloading Update 13 to see if that helps (I'm using 12 currently), is there anything that I may being doing incorrectly or are there some things that I need to be aware of?
No luck with update 13 either I tried exporting from both OpenBuildings and OpenPlant, yet still no lights.
Hello Lucas,
Thank you for letting us know the concern you are facing.
I will check and get back to you as soon as possible.
Thanks.
Rg,
Ankur Ashesh
