I have a very basic rectangle with a aerial image assigned with the DC drape material. When I export this to LumenRT using the export large model option, I have a issue because after the file is exported to LumenRT the aerial image turns to solid black.
Is this a common problem? Do I need to make a adjustment to my dcdrape material, or is this something I need to change inside LumenRT? I already updated from a much older version to the most recent update 13 and have the same issue.
thanks
https://communities.bentley.com/products/microstation/microstation_visualization/f/visualization-forum-1977638070/145843/lumenrt-arial-image-rotated/447706#447706
I found this and this seems to work for me. Once inside LumenRT I am able to pick the dcdrape material and load the image file for that material.
