I have street lighting cells that have spot lights in them. In microstation they point down and look great, however when i export to LumenRT they are all pointing the wrong way. They seem to be all pointing to the same point away from the road, which is a bit weird. The street lighting cells are not the standard lumenRT ones, as i wanted to use ones that looked more like the ones on site. I have added Spot light elements which do work in both lumen and microstation, just seems to be the direction that is the issue. screenshots attached
Has this happened to anyone else?
I'm using LumenRT Connect Edition 16.12.23.02
I'm also using Micorstation Connect Edition 10.10.0.23
Can you share the files for review? You can use the following link:
https://bentley.sharefile.com/r-ra8e28c8e2c8493ab
I've saved the street lighting in a new DGN, it exports the same way into LumenRT.
Thanks for your help
Good to hear. I did review the original files you sent me and the issue seems to be caused by one of the the axis scales for the spotlight cell.
Not sure how this would be caused though.
