LumenRT interpolation time
How do I get rid of the "interpolation time" for the whole movie the movie isn't smooth!
Animation export form MicroStation Updt 13
https://vimeo.com/366223214
//Christiaan
  • Hi Christiaan,
    It seems like the keyframe position interpolation has been set to Ease In/Ease Out. This would cause the movement to pause momentarily at each keyframe.
    To fix this you can try the following procedure:
    1. Click the Toggle keyframes/splines button to enable spline editing
    2. Make sure the Camera position option is activated (orange)
    3. Do a drag select around all of the nodes on the splines
    4. With all of the nodes selected, right click in the spline area and choose Smooth(Weighted) from the top of the list of interpolation choices.
    This should remove the momentary pause at each keyframe.
    Ron
