When visualizing ConceptStation in Lumen, the Bing imagery is missing from the 3sm display in Lumen RT 13. It shows correctly in ConceptStation. Is this a bug?
LumenRT Update 13 and ConceptStation 10.00.10.17
UPDATE*
I've updated ConceptStation to 10.00.11.32 and have tried visualizing on two different machines. The issue still persists for Bing streaming but static imagery works.
Hello John,
Thanks for the input, will have a look and let you know
as soon as possible.
Rg,
Ankur Ashesh
I've tried to replicate in Concepstation 10.00.11.32 and LumenRT Update 13 and do not get the issue.
If you use static imagery do you still see the same issue?
