I have exported a terrain model from Openroads into LumenRT for a project display. When I assign a grass material to the surface I get this:
When I zoom in the grass fills out a bit more but just around the edges of the patterns.
What is the reason that the grass doesn't render across the entire surface correctly and can it be fixed?
I am using LumenRT Connect Edition Update 11
Thanks for any help
Hello Taylor,
Try to use normal texture like image, png or jpg file format image of grass texture.
And please check if you can update to the latest version of LumenRT update 13.
Update 11 is quite old now,
Thanks.
Rg,
Ankur Ashesh
Answer Verified By: Taylor Brownlow
