Hallo
Default settings of the light pole (Tall Street Lamp) looks like it needs to be adjust a bit (pic attached)
Making the pole higher (for example ca 3m) this lighting area is disappearing.
There are two windows I found for adjusting the light of the Tall Street Lamp: setup and properties.
After adjusting It more or less It's needed all the settings are gone when I open LumenRT next time.
Is there any way to keep all changes done to stay saved ?
CE 12
Maksim
