Hello
is there any new options in Connect to export to Max with camera and lights ? This is only Max import problem or export ?
As we check only point lights is ok, spot lights goes other direction, and one camera made by animation actor is far away….
I found something like this importer / exporter but not so cheap and works with v7
www.okino.com/.../imp_dgn.htm
