Is it possible to make the clipping planes transparent? It seems easy to change the colour, but viewing the model through a clipping plane can tint the whole view and make the plane itself more visible than I'd like.
Currently you cant change the transparency, I will have to check if this has already been requested as an enhancement.
Depending on the complexity and size of the model you may want to resize the extents of the clipping plane. You can do this by using the element selection tool and in the properties disable the infinite setting.
Answer Verified By: tom pike
