Im new to LumenRT but I'm following the instructions forom Kurt Rasmuss "TechTalk" verbatim as he gives them, I'm trying to load my reality mesh scene on LumenRT, but what pops up in the LumenRT window is just a basic default grass distant mountain scene, my 3SM relaity mesh is nowhere to be found. I'm use to VRay in sketchup just popping the scene right up.
What am I missing here? See attached screen shot of grass scene
Hello Brian,
May i know which product from you tried to export ? is this file export correctly from Microstation ?
What is LumenRT version
Thanks & rg
Harshad
I am working with a 3SM reality mesh inside OpenRoads Designer
Hello Brain,
Can you try to load the .3sm file directly inside LumenRT.
Please try this at your end and let me know the results?
Thanks.
Rg,
Ankur Ashesh
I figured it out
