[LumenRT] Mstn Saved / Dynamic Views Transfer
Are Saved / Dynamic Views honoured in LumenRT?
1. Ref attachments are an essential workflow for Mstn. Saved Views are used to store Ref attachments / level settings... as well as camera related info. Will these be exported and understood by LumenRT?
2. Ditto for Mstn's Dynamic Views, which provides clipped views that are essential for 'peeling back' BIM models. Without this, it would be pretty usable to work with(in) BIM models.
  • 1. Ref attachments are an essential workflow for Mstn. Saved Views are used to store Ref attachments / level settings... as well as camera related info. Will these be exported and understood by LumenRT?
    The level settings in the view are honored when exporting to LumenRT.
    The same applies the way elements are clipped in MicroStation are honored in LumenRT, but you wont be able to adjust the clip, There are clipping planes you can create in Lumen if you need this functionality.
  • Thanks for the reply and Happy New Year!
    1.I noticed you only mentioned levels but not Ref attachments. I presume that this is because Lumen can not import dgn's etc...yet?
    2. Not being able to adjust the clip is a little half baked and severely limits the effectiveness of the tool. Can the SV be converted to a LumenRT clipping plane easily (ideally, one click)?
    A  bidirectional Clipping Plane would be useful to have as well to spare the user needing to replicate the clip in Mstn after he has found something in LumenRT.
