I've added some text labels to an animation and set them to custom levels. I later made a small change to the original MicroStation Model and re-exported it into LumenRT. I expected the scene to include the update but be otherwise unchanged, but I lost the custom levels and it seems the text now does not have a level assigned to it (it didn't revert back to the original/default text level). In this case I can delete the text elements and recreate the levels, but thankfully I only had four text labels. Did I do something wrong? Is this a bug you are aware of?
Tom
Hello Tom,
Thank you for the information, will have a look at this.
Rg,
Ankur Ashesh
Please raise the Service request for the same.
It's a defect and we have created the defect for the same issue.
Will be addressed in future release of LumenRT.
Thanks.
Answer Verified By: tom pike
