How to I adjust the display resolution of my model/interface when the camera mode is off.
When I click 'normal camera' in view perspective for example the display is high resolution and I can dynamically move the view with a clear display, however I click 'camera off' it switches to an low res version with lots of messy edges. As if it is giving me a low quality display to speed up the interface.
I assume this is an easy setting to adjust somewhere?
Thanks.
James
Which software are you using?
If in MicroStation a view does not have a resolution rather a size and the resolution is that of the monitor.
Can you share some screenshots of the issue.
