Hello Dear Support People,
I have a think with my extrusion function, I am trying to extrude some lines and it is not possible. Can someone explain to me?
Thanks in advance
Anastasia
Hi Anastasia,
please follow the communities best practices: Without knowing what product and version (the product build number at best) and other information your question can hardly be answered.
With regards,
Jan
Hi Jan,
first thank you for answering, i have Microstation V8i select series 4 and i have solved the Problem. I used the extrusion command R.1 but i used the wrong drawing tool.
With best regards,
Which specific extrusion tool are you using? there is the Solid Extrude which requires a closed element to function. Whereas Surface Extrusion can extrude open elements into a surface.
For help on specific tools you can refer to our online help documentation.
Answer Verified By: Anastasia Mesemanoli
I assume that you tried to use "solid by extrusion" tool; but that cannot work for "lines"; the line must form the closed shape; only then "solid by extrusion" would work.
To extrude line, use need to use "surface by extrusion".
Nikolay Vyglazov
