Is is possible to copy LumentRT content between different scenes?
I have some trees and characters placed in one scene, and want to reuse them in a new one.
The reason is that i had to expand my terrain model und Lumen does not render the expansion, so I created a new file in microstation, which exports fine.
But now I have to redo all the Lumen stuff...
Lumen RT update 13, exporting from Microstation SS10.
Nice one, Karol... nothing clearer than a binary sketch!
Max
maybe comment in step 4 ,
repair, add or delete, what you need in B.dgn
add refs as you wish, the same name of levels from refs will be placed in one level in lrt !
I hope it is understandable
:-) /karol
Hej Karol
thanks. It didn't work in this case, the lumen objects are there, but the scene is still incorrect.
I will redo the neccesary stuff manually.
/Martin
