I get a strange behavior with the attached DGN File.
View top, render continue, camera on : Correct
View top, render continue, camera off : inCorrect
Also when dinamically turning the view, the display suddenly disappears and Accudraw Z jump from 0 to -7000000...
8473.8F01-4.dgn
Hi Remy,
VIew 1 has active Z set to -32553495.9853, and display Depth to -66409133.4218,1302411,4513 so I guess that's the reason for the view/Accudraw jumps ...I selectall elements in file, saw there was a missing PFD file attached as a raster far from the model, I deleted this guy, fit all and then evrything was back to normal.
MS_10.13.00.48 (did not have 10.12 to test...8473.8F01-4_OK.dgn
Vincent RAULT [Bentley]
Answer Verified By: Remy Weil
