I have a material size issue when i put in reference a drawing from one file to an other file. I use connect edition v13 and don't know why the size of the material is not good in reference. But when the material is in surface mode, so the size is good but with meter, the size change !!!
I used the following steps : add material to solid in a 3d model, creat a drawing model, put in reference in a new file the drawing.
can you reproduce the issue ?
hope you will be abble to help me.
thanks,
Fabrice
Hi Fabrice,
Can you attach an example dgn with the texture image of this issue and we will take a look.
Paul
Hi Paul,
Here are the files. I juste kept the solids with the problems because the file was too heavyMaison_du_Bois_CE1000_esquisse_3D_V8_PROP_2.dgnMaison_du_Bois_CE1000_esquisse_ASSEMBLAGE_V8.dgnMaison_du_Bois_CE1000_esquisse_IMPRESSION_V8.dgn
I use 3 files, the first is the 3d model, the second is used for the drawings and the thirsd one is used for the print !
the problem is in the print's file.
Thanks in advance.
cheers,
Note the file Maison_du_Boris_CE1000_esquisse_IMPRESSION_V8.dgn working units are different compared to the other files any particular reason for this and not using same units ?
vs
Carl Myhill
Technical Support Engineer
Bentley Systems
Answer Verified By: Fabrice K
Hi Carl, No reason, I think i took old dgn and maybe there were mistake and I didn't seen that before.
I change the settings and now everything is OK. I forget to take a look to these settings.
Thank you very much,
Best Regards,
