Hi It has been a while since I used MS for textures. There has been an option in MS Descartes for wrapping a rester to the area (flat surface) and then with the use of analoge points attach the reater to thst surface, later to creat a texture out of so transformed ratsers (assign to area, Texture tools -> wrap to area). Can you tell me is that option avalable in Connect? I can se the wrap but I cannot see the asign to area option and wrap alone does not work well. If there is not, is there a fast tutorioal on how to cerad a dcwrap and place it in a correct place? Sorry for asking such basic questions.
perhaps the following would be helpful:
https://communities.bentley.com/products/microstation/w/microstation__wiki/10792/draping-a-raster-file-on-a-solid-or-dtm
