I am trying to alter the color distribution of vehicles which I import into LumenRT. Is there a simple way to set the range of colors a vehicle can display as? For example, I have a lot of vehicles showing up bright green or yellow. I would like to keep them in the gray, black, navy range.
The vehicles are coming from a Vissim ani.txt file.
Thanks!
This would be useful - some of the randomly assigned colors are quite startling.
I will have to inquire with development are there any sample files you can share to test.
Thank you! I will share those files with you.
