Hi - would really value some advice please. Home working configurations are causing a nightmare with material pallets. Running CONNECT 18.25 on home computer. Can't access the .LXP materials. No previews and new .LXP materials to the material folder do not appear in the Luxology Presets Pallet.
Config is pointing towards the correct folders..
.lxp materials are located in correct folder but not showing on Luxology Presets Pallet.
Paul thanks for reply. Though not too clear on this - I have additional lxp and placed these within the folders identified in Config settings (left screenshot). However I cannot see these when browsing the Material Pallet under Luxology_Presets (right screenshot), I also do not get any previews.
