Hi
We need to import a number of text objects into LumenRt. Text can be easily exported form DGN file, but what we need is to have this text view independent, so it is always oriented toward viewer/camera.
When you place TEXT with Lumenrt there is an option to set text as FaceMe and it is then oriented toward viewer.
text we need to have in lumen rt oriented toward viewer is: stations every 25m along 15 km long corridor, over 300 plot/property numbers. Imagine placing all these text with lumen will be quite time consuming while all are done in Microstation.
Thanks for you support!
Adam
Hello Adam,
I hope you have already created the service request for the same.
And we have taken you points.
Will addressed you soon on this.
Thanls.
Rg,
Ankur Ashesh
Hej
Service Request 7001072895
Enhancement number is 1095643
Such py script would have a number of potential applications.
Thanks!
Best,
OpenRoads Designer 2023 | OpenRail Designer 2023
