LumenRT Plugin for Sketchup
Hello, I am trying to download the LumenRT plugin in sketchup 2019 bust cannot even find it in the extension wherehouse, can someonr explain to me the workflow procedures to install this in sketchup?
  • Hello Brian,
    Just install the LumenRT update 14 latest released build on the top of sketch-up 2019.
    Once you run the set-up file of LumenRT,
    After 2 step you will pop up a window of Plug-in option and then you can select sketch-up 2019
    Although by default it will select automatically select sketch-up 2019, but just to be sure you can see the tick mark.
    And after install the LumenRT update 14 you can open sketch-up and see the plug-in option.
    Please let me know if this will help you.
    Thanks.
    Rg,
    Ankur Ashesh
