I'm new mebber of the community.
I've just installed Microstation updt 14 with defaults: LumenRT and Descartes.
When I try open LumenRT while open MicroStation (MS), I could not.
User do not have licence of Bentley LumenRT but I expect, that MS opens LumenRT Designer. But do not! What should I do to run LumenRT Designer (I have licence for it) instead full LumenRT?
Thank you in advance
Just noticed you post in the Archived] MicroStation V8 2004 Edition DWG Forum. This is not monitored as readily but as a moderator I will reassign to the most appropriate forum.
Can you clarify a bit more on what is happening when you try to open LumenRT, is there an error message?
Hello Jerzy,
There is some step you needs to follow in order to run LumenRT designer:
Follow this wiki to do the same.
https://communities.bentley.com/products/licensing/w/licensing__wiki/38028/2---entitlement-management-configuration
what you can do to make sure it is completely uninstalled:
Please let us know after they try out the process.
Thanks.
Rg,
Ankur Ashesh
Contextcapture?
