I have created a model in ConceptStation, exported to OpenRoads designer and used the script camera path to create a fly over of a project.
The preview in OpenRoads looks great. When I export to LumenRT it drops a keyframe every two seconds. Instead of flying through the project at a consistant slows down as it approaches each keyframe and speeds up as it leaves that key.
Is there anyway to get the path to stay a consistent speed through the project?
Can you share the files for review.? If so please use the following link:
bentley.sharefile.com/r-r32c924e45504b4bb
