I have simple file ( Attached )
but both v8 and Connect give me 0 Kb file...
I try SKP too.. Interesting is that i can export SKP only to other folder than project folder. When i export skp to same project folder it show 0 kb...
Can anyone look at this ?
THank you
Martin
mlyn.dgn
Hi Martin,
I was able to export your DGN to FBX without any issue, the result is attached.
The latest MicroStation CE Update 14.2 used, running on Windows 10, fully updated.
Used "no workspace" workspace, opened from a general folder, exported to the same one.
With regards,
Jan
mlyn.fbx
Thank you Jan
i don't know there is a problem with Nvme ssd or what. I saw sometimes this problem. Will check in newest. Thanks
